- Sun Mar 31, 2013 9:58 pm
#23651
Hi guys ----------- and well done lads for putting across simply what to some people is a "Black Art" of fuels and combustion...How often do you hear someone say that "The fuel explodes and---------------- etc, etc"..It actually BURNS and takes a measurable time in so doing..........Ideally we would want the fuel/air mixture to be ignited spontaneously and equally within the combustion chamber------but, to date this hasn't been achieved, as far as I'm aware that is, so the nearer we can get to this ideal the better.....Now remember TREVORCH's reference to start-up checks on the twin magnetos??--- and NICO with the FORMULA 1 3-plug idea ?? It's actually the EFFICIENCY of the combustion process that's being improved.. ie getting as near as we can to burning ALL the fuel/air mix within that combustion chamber with absolutely NO unburnt HYDROCARBON fuel particles left over whatsoever...........Those of you who have changed from the standard CB points ignition to an electronic system will probably had to lower the idling speed ?? Same thing being seen from a different standpoint........With regard to the fuel/air mixture it's somewhere in the approx. ratio of 13:1 (can't find on my Apprentice Tech. notes at the moment for a more accurate figure)... This means that we need 13 weight units of air to 1 weight unit of fuel (which now has a 5% Ethanol stirred in !!) to give a mixture that SHOULD give complete combustion in IDEAL conditions........... Have a look at this }-------- http://www.engineeringtoolbox.com/air-c ... d_212.html -------------- notice that Oxygen is approx 20% whilst Nitrogen is just under 80% !!! It's the Oxygen content that we are after as it increases the RATE of combustion ( but does not burn by itself ie it's not a hydro-carbon )whilst Nitrogen is INERT..doesn't react with Oxygen, and just passes straight through..In other words it just gets in the bloomin way and has a free ride on top of the piston in the process....... That's enough for now 'cos my bonce is aching !---- Has that helped a bit ??...............I hope so ( ps, have a look at High-speed diesel injection systems, dual-stage injection process and bowl-in piston crown aligned to hemi-spherical cylinder heads )if you're a glutton for punishment !!!!!!!!!!!!
