By Bonnevillesmith
#1936
I have a BSA B31 fitted with a 376/29 1" Monoblock. What ever I do I cannot turn the idle speed down. The slide is at the bottom and is a good fit/not worn. I have also checked for air leaks at the manifold and there are none. Any ideas?
By DUFFEL
#23465
Hi Bonnevillesmith You could try a slide with a smaller cutter way Is the inch bore carb correct for that model I would have thought an 1.1/16 bore ??
