- Mon Feb 11, 2013 10:49 am
#22347
Hi guys and thanks for your support ( I shall wear it often !!)--------- I forgot to mention that there are 2 plates -- one either side...WINKIE, my bike is a Home market one as well, but the head is from a European model....The lower bolt is the original "across-the-frame" one whilst the top is an 8mm, flush-welded to the bracket which are then both pre-assembled into the tank's mounting lugs before lowering the tank down and over the mainframe..The steel is 1" x 1/8" bright mild and the hole centres are pitched at 3/4"....From a distance you can't see the join, in fact NORM tells me it looks bloomin marvellous from his house !!
