- Tue Feb 05, 2013 8:38 am
#1769
My Inter occasionally jumps out of first gear at the most inconvenient of times, like taking off from lights and turning a corner, bike leaning over and you loose momentum. Detent is in as far as I can set it and it was replaced 12 months ago. What I want to try is grind the first gear notch in the gear operator but not sure if I can do this in position.I don't mind stripping the box to get at it but I don't want to do this and then find I have to pull the motor anyway.I'm thinking of getting in there with a die grinder maybe. Anybody tried this?
