I found a strange KLG FE220 spark plug in my replacement head. looks like it has an adjuster to set the reach and the electrode is flus with the threads. I will post a pic if someone tells me how .... :/
Hi guys--------- well I never knew that about the Guinness connection !! Have a look at this }---- http://www.gsparkplug.com/shop/spark-pl ... fe220.html -------------- It's not for adjustment, I believe it's to dismantle the top from the bottom. It's how a lot of the early plugs used to be made..ZIPPY, they weren't kidding you...it's a plug designed mainly for racing or fast street use...
Hi zippy: If you click on the HTML code near the picture in Photobucket, it should appear on here without having to be copied and pasted in the address space at the top of the screen.
