- Fri Jan 11, 2013 9:38 pm
#1691
Hmmm, new issues! Turning the ignition key mostly starts the ECU and fuel pump, but once in a while there is a click but nothing starts up. More interestingly, in the normal circumstances where the ECU and fuel pump start up (and neutral light comes on) pulling the brake lever or pushing the back brake pedal trips the electrics off. Totally. Lights and all. I spent the last two hours checking all connections in the headlight nacelle - none seem to be the source of the problem. It could be the ignition itself, but I doubt (no idea why I doubt it - I just do). The neutral light switching off concerns me, and the wee red light under the fuel warning lamp glows when the front brake is pulled - so I think current is leaking somewhere between brake, neutral and ECU. So, my question, any ideas where to look? Does anyone know where the earthing points are? I'll keep looking... I hate electrics
