- Fri Jan 04, 2013 9:28 pm
#21174
Hi again, I had no problem with both nuts hand tightened first (the shakeproof washers help to stop the shaft turning) then just using the socket either side to tighten up. Remember to put the swing arm in its 'mid swing' position(i.e. half-way through its possible normal travel if the shocks were fitted in place), before finally tightening. That's to stop excessive 'back & forth' twisting of the bushes which might cause them to fail prematurely.
Just realised might not be able to make Tuesdays meeting but will definately be up for Sundays hike & meal!
Mick
Mick
