- Tue Dec 18, 2012 7:06 pm
#20689
Hi Guys--------- Am I glad that you have posted this problem. Not that I have any pleasure in your misfortune Mikey238 but because I also have recently removed a Hitchcocks O/S Ex. valve that had done just 3,250 miles before giving signs of failure...Upon removal it looked EXACTLY like yours, complete with all those little "flecks" attached to the seat area.....I returned it to our hosts for inspection---- their initial response was that the engine was running weak/hot etc... I pointed out that it was set to their recommended jetting figures and that the plug was quite normal.... They have sent it away to the manufacturers for their comments....This was approx 4 - 6 weeks ago...NOW, here is a common factor}---- That particular head is from an Indian home market bike which has done 12,732 Kms (about 7,500 miles) and the big valve was fitted as a direct replacement for the Indian original.. The exhaust seats that Hitchcocks supply ARE of European make but are NOT advertised as being hardened ie by implication they are therefor to ORIGINAL spec. ergo that's where the problem lies IMHO... I'm visiting the "Chaps at Chadwick" this Friday so will bring this post to their attention...Their larger exhaust valve (with extra slippery coating etc.) is advertised---as I understand it----- to be a direct replacement for the standard Ex. valve based on size alone.... There would appear, at this stage at least, to be a compatibility problem between the valve itself and the material the seat is made of...as PETER 53 says}--- he has a HARDENED seat, US made, with Hitchcocks larger valve and that combination is working OK....
