- Thu Jan 03, 2013 11:21 am
#1655
Hello, this is my first post, please be gentle!
A few months back after passing my motorcycle test aged 29 I purchased my first motorbike, a used 2011 Bullet Electra EFI, under the guise of commuting but also as an entry point to the wonderful world of motorcycles and I have loved every wind and rain lashed second of it!
Due to a failure of the tail light I need to replace the unit. After consideration (with a mate, in the shed over an ale obviously) I am going to take the opportunity to slim down the rather bulky and in my opinion unsightly tail light / indicator cluster.
My main query is that I am considering buying smaller indicators and moving them back to sit above the rear shock mounts. To my mind there are two obvious options for doing this. The first would be would be to drill a hole for the indicators in the large steel plate above where the rear shock is fastened (just below the saddle) or the second option would be to weld a tab on just behind the area I just described for the indicators to be mounted on.
Just wondered if anyone has had an experience or thoughts on this matter before I crack out the drill!
Thanks for any help / pointers would be greatly appreciated!
George
George
