By llyn guevara
#1652
It sounds a really simple one but my petrol warning light stays on even when it's full. I can't find anything in the service manual. Any ideas?
#21110
Hi Matey---------- my(our) usual response for these newish bikes ie}--- Is it still in WARRANTY ?? If so pop it in to your nearest dealer---with the relevant paperwork--- and they should sort it for you.---- If it's out of warranty then it's probably as per GRUNDA12 ie a stuck sensor (normally a float working a variable resistor/rheostat)within the fuel tank....There is also a REMOTE chance that the wiring attached to the sensor has short-circuited somewhere giving a permanent reading.. To check that scenario try disconnecting the two electrical leads that are attached to the underside of the fuel tank.NOTE !!!!!! >>>>>>>>>>>>>>>>>>>>>only do this WITH THE IGNITION TURNED OFF ie NO SPARKS !!!!
By Gwilly
#21142
Alans on the money, sound advice.
Press the button and fly over to our american brothers.
It seems they have simular problems.
Nice picture in the thread of the offending switch.
yall come back na yahear.
button
regards gwilly.
