- Sun Dec 23, 2012 11:53 am
#20976
Hi Norm,
There are some dodgy plug caps around these days and by coincidence, a Meteor [single carb] I worked on recently would run on both sides to begin with, but gradually begin to miss on one side, then lose it all together. Everytime I took the plug out to check it [and not really find anything] and put it back in, the engine would run on two again, before the same thing happened again. It turned out to be a duff [brand new] plug cap and the internal connection where it goes through 90 degrees was faulty. Everytime I replaced the plug cap after checking the plug, it remade the bad connection, until the vibration from the running engine shook it apart again - took a while to realise what was happening, but a second brand new plug cap sorted this machine.
Cheers,
Paul.
