- Thu Dec 20, 2012 9:24 am
#20887
Hi MATT----------- oddly enough I'm agreeing with the sentiments that's in STRINGERS post---for the moment, that is...You appear to have found a "Hot-start" technique that works for you so I would just "ride & enjoy" and get some "bonding time" under your belt....(Sorry, that's just an old farty-bags keeping it real, innit??)..However,one REAL bonus with a 1970's 2-stroke single is}--- mechanically it's about as simple an engine/carb. that you are likely to come across in motorcycling---(being no Gas Turbines out there I think??), and unlike your 2 Enfields there's NO}---Vertical split crankcase, timing gears, cams, push-rods, valves & their parts, oil pump, points,(my Grass-Tracking Montessa's and Bultaco's had solid state electronic ignition as standard), seperate gearbox..Similarly the carb. with a couple of jetting "tweaks" is identical in structure and operation to a 4-stroke one...Here's a couple of suggestions to be going on with..a)Obviously try any dedicated forums for Montessa and ---b) Are there any 2-stroke owners in your area ?? eg BSA BANTAM, Classic Japanese Bikes such as early Suzuki, Yamaha, Kawasaki...or even the little Peddle & Pop guys on Mobylettes or Puch Maxi etc...Collectively (and lovingly ??) known as "Stinkwheels" these 2-strokes are easy to run/maintain...Sorry to bang-on like this but it's a re-visit to a happier time for me...Final tip }---- remember ALL engine lubrication is via the fuel/oil mix so do stay with whatever the previous owner has told you he's used......Do you know, I've suddenly got the urge to have another Bultaco Sherpa !!! Stop me someone, stop me !!
