- Fri Mar 29, 2013 3:04 pm
#1968
Hi Guys.
Further to my query a couple of weeks ago about shimming the cams and idler pinions in my 1996 500cc Classic, I followed up on advice to try Plastiguage. Great stuff but expensive here (its about twice the UK price of GBP11 for 10 sticks).
I found Mr H’s performance cams to have little end float, perhaps 5thou but the idler pinions have 20-25thou end float. Do you think this end float would cause excessive noise? I could take out most of the shims but woudl have to have new ones made as our host only sells the idler pinion thrust washers (PN 140121) which are ~50thou and too thick.
The remainder of the engine noise, most of it, comes I think from the worn rockers which I have still to resolve - easy to replace but hard to explain why they wear out so quickly especially as I have put in the high capacity pumps.
Thanks in advance for your comments.
ChrisD
ChrisD
