- Fri Oct 05, 2012 7:38 pm
#1267
Hi Guys.
My 2008 k/s 500 classic 5000kms spits back when opening up the throttle above halfway.
I have an unrestricted silencer and conical S&B air filter fitted.
Since fitting the air filter I have richened the Needle Jet P2 and Slide 2 1/2, also tried needle groove positions; lowest, 2nd to lowest and middle.
Present config. is Idle Jet--30, Needle Jet--P2, Slide-- 2 1/2,Main Jet 120. It starts well and ticks over fine. I have fitted a new inlet rubber and new coil (cos i had one on the shelf)Tappets checked ok,Boyer Bransen ignition installed.
It doesn't pull very well seems sluggish, up hill especially, since fitting the air filter. When I open it up it spits back through carb and hesitates, while this is happening, if I push enrichment lever down it revs freely stops spitting and storms up the hill. i have tried a plug chop but its abit inconclusive, cental electrode appears abit light in colour.
I know this problem is abit of old chestnut, any ideas why carburation appears so critical on the bullet,other old singles I have had would accept virtually any carb from the jumble and run reasonbly well.
Any help would be appreciated.
