- Wed Oct 03, 2012 3:52 pm
#1251
Hi all. I've just completed the rebuild of an Electra X engine, I hope. New main bearings, oil pump worm and shaft and new barrel and piston. Special thanks to Norm and Les H for their tips on getting the inner bearing races on the crankshaft. At the moment I've got semi-synthetic oil in the engine, and was wondering if I should change it to a mono grade for running in or not.
I also have an oil leak. The barrel has a tiny 1mm hole through which a lot of oil comes out. Is it possible to plug this with something? Many thanks for all advice.
