- Tue Sep 25, 2012 4:30 pm
#17772
Trouble is John, the dial guage will be more accurate than the engine. The engines are pretty crude and the "correct" timing is not necessarily right. All that backlash in the timimg gears makes the "correct" figure just a starting point. If the dial guage was fitted in the plug hole it would need to be a special anyway as it would be reading at an angle. Use a drinking straw (or Mr H's little timing tool that fits in the plug hole) to set the timing. After that, tweak it a few degrees till it runs right. It's best to lock the auto-advance at full advance and static time it there, as that's where the engine spends most of it's time. Mr H sells a little tool to do this too. Always approach the correct setting BTDC by moving the engine forward to take up the backlash. The real way to get the timing spot on is to do it dynamically but that's a bit of a palaver and not really necessary for a "cooking" Bullet.
Classic C5 Euro 4 at the moment.
Also CBf250.
