- Tue Sep 18, 2012 8:47 pm
#1182
For some time now my Electra X has had sloppy handling.
It feels as if the swing arm bearings (or are they bushes?) have play in them. Or maybe there is play in the forks from somewhere.
I've lifted the back wheel and given it a good pull around to look for play but nothing. I changed the rear wheel bearings a thousand miles ago as part of searching for the same problem. No change.
Problem is worse two up not suprisingly......like having a flat back tyre? Weaving in bumps at speed.
I've also checked the head bearings and found no notchieness.....I think I've adjusted them right as on lifting the front wheel from the fork bottoms I can feel no play either.
I'm not familiar with these type of forks having only stripped those from a Honda VFR.
I do need to get inside the forks at some point soon to fit the improved springs from our hosts. Could wear from some internal part be to blame?
Clues anyone please?
