Norm, yes they will but the Indian fork tubes (stanchions) are slightly thicker walled so you may not be able to use the original Redditch springs. If you go for Indian springs go for a lightweight set as supplied by Mr H as the standard Indian ones are rather heavy. I have done this swap on my 59 Trials which uses the same components.
