- Mon Sep 10, 2012 10:29 pm
#1135
The rear light has started to remain on permanently on my 2008 350T, all other lights respond to the switches but the rear light stays on. When I press the rear brake pedal there is no discernible increase in illumination of the rear light so my initial diagnosis is a fault in the brake light switch. I've tried moving the plunger on this switch, as well as disconnecting the spring to the brake pedal but the rear light remains resolutely on.
My next action is to disconnect the wire to the brake light switch and see what happens.
Anyone else had this happen or got any ideas?
