- Mon Aug 20, 2012 10:08 pm
#16447
Thanks Dennis and Paul,
I'm aware that it won't have the dynamo drive sprocket and I would have to attatch one, problem being that the 54 has a 30/15 tooth dynamo sprocket setup and I want a 19/19 tooth to drive the Pazon ignition at half engine revs. Mr H has said the twins cam sprockets are the same so I am hopefull that I can use the sprocket from a Series 1 Inter and all would be good. The Pazon is designed to replace the K2F mag and I have a K2F mag sprocket which is a duplex chain, so the Series 1 Inter would be perfect.
