- Sat Dec 29, 2012 8:17 pm
#1640
May I request your help please. My Bullet 4 speed gearbox is spiting out grease through the output oil seal. New seal and sealed bearings a few years before, without any leaks, then all of sudden the dreaded drip, after a long run. ( The seal has been removed and found to be in good order, still flexible and no sign of ware). The gearbox temp has been raised along with internal pressure, which I assume is pushing the grease out. Which leads me to the question, through ware should the gear box breath. I am thinking of drilling a hole in the filler bolt, about 0.5mm, to come out in the middle of a flat of the bolt head, facing backwards, to keep the rain etc out.. Any suggestions …. Martin
