- Sat Aug 04, 2012 10:57 am
#935
Whilst I'm in here, I've had to get a new speedo mechanism for the front wheel and it seems easy as to fit it but I'm trying to find info on how tight the two nuts on the axle are meant to be. One nut is on the front break side and the other is on the speedo side. I've not started as yet but I assume if you tighten these too tight it stops the front wheel rotating? Or at least adds more friction? Is that the case or is it a case of tighten as tight as you can. I assume as one wheel is in the direction of wheel rotation it'll get tightened by the bike's motion anyhow. That'd be the speedo side I assume.
Sorry I hope all that makes some sense.
