- Wed Jul 25, 2012 9:45 pm
#877
I HAVE A BULLET 500 WITH A MIKCARB FITTED AND RECENTLY HAS STARTED PINKING WHEN UNDER LOAD OR GOING UPHILL IT HAS A SHORT SILENCER AND WHEN I STRIPPED THE CARB THE CLIP ON THE NEEDLE WAS IN THE BOTTOM GROOVE WHICH IS RITCHEST SETTING I FITTED ORIGINAL SILENCER ON IS IS STILL THE SAME AND ON REMOVING PLUG FOUND IT WAS NEARLY WHITE INDICATING WEAK MIXTURE ANY IDEAS PLEASE
