#14832
Les,
You are probably right, but flashers on there bikes do bizare things
By roberto
#14855
Hi all,Thanks again for info, tried all to no avail except for Pete F input (fit diodes) whitch I will try next regards Bob.
By Les H
#14856
Hi roberto.....What bleeper do you have?......If it has two red wires, I would imagine the diodes are built in?....If not Pete's method with diodes fitted is correct, although with a simple bleeper they are not required as long as you wire onto the input side of the turn signal switch.....not the bulb sides.....It could be that the diodes (if incorporated inside the unit) have become faulty and the effect is shorting and connecting both left and right side indicator bulbs together thus changing the flash rate. If this has happened....just use one red wire (or use both together) and connect them either directly to the output of the flasher unit or where the wire from the flasher (Red/White or Red /yellow) connects the indicator switch wiring. Should be ok then.
#14858
-------------I've just been arrested by the Police because I mis-understood the meaning of this listing's title !.!.!
