- Mon Jul 16, 2012 8:07 pm
#14821
Hi Nellie,
I know you have tried all manner of things with your bike & the help you have received from the boys here will have been great they realy are a fantastic set of lads.
Nellie the next time you take the generator cover off try this!
Make a small pointer out of white cardboard say & stick it onto the cable clip that holds the three wires going to the alternator coils with some blue-tac. making sure the pointer is just above the rotor then set the engine at T.D.C. on the compression stroke, then make a mark on the rotor to match the pointer, this will give you your reference mark if you ever set the ignition timing again,
Geoffro is correct in saying that 1/64 = 5 degrees, so your rotor will be the same as mine at 70mm,
multiply the rotor 70mm by 3.142 = 219.94mm lets call it 220mm, so your circumference of the rotor is 220mm now divide 220mm by 360 (degrees) and that equals 0.61mm for one degree, so multiply 0.61mm by the 5 degrees needed for your timing & that comes out at 3.05mm, lets call it 3.0 mm, so you now have a reference mark on your rotor for T.D.C. now if you make an other mark to the right of this at 3.0mm then turn the engine back till the 3.0mm mark lines up with your pointer then that is bang on to set your timing IE points just starting to open.
