- Wed Jul 04, 2012 10:01 pm
#757
Greetings one & all, can I pick your brains please?
I have a 1960 Super Meteor (700cc twin) and from day one it has had a misfire when it gets warm, this usually shows itself after 25-30 miles when I slow down for a road junction and notice that the engine won't tick over cleanly, i.e. missing on the lh cylinder.
I started by checking & replacing the plugs, caps, leads, points, condenser, checked the points gap, checked the ignition timing, advance bob weights, did a compression check and the valve clearances! After all this it was still there, just when I thought I had nailed it, back it would come.
So I ditched the dizzie, coil set up and fitted an SR2 magneto (as fitted to earlier models) ticks over beautiful, looks like I've sorted it............nope, it's back, so it can't be ignition, right?
Carb has replaced too! New monobloc with recommended jets etc, also made sure there were no air leaks on the carb mating surfaces & manifold.
So over to you, I'm going to the Manx in August (hopefully) what am I missing?
Thanks for all your inputs (and sympathy), based in Gloucestershire if that helps!
