By Anders F. R. - Mon Jun 11, 2012 8:55 am
#611
Case: The engine has been running rich for the last 6000 km, but maybe much more if it did so also with previous owner. Black, sooty plug every time I have checked, but otherwise running well, easy start, consumption within what is expected etc., so no big issue really. For some strange reason I have only checked that all jets are correct, which they are, air filter OK, tested warmer plug (without any improvement) etc., but not until yesterday got the idea of lowering the carb needles one notch. (Stupid, I know! Never assume anything is correct just because the book says so.) (I may also have mixed up 2nd notch from top and 2nd notch from bottom....).-.-.-.-.-.-.-.-.-.-.-.-.-
Anyway, I lowered the needles one notch, and no more sooty plugs! But I can only guess that the rest of the head and piston top is rather full of carbon too. .-.-.-.-.-.-.-.-.-.-.-.-.-
Question: So what should I do about that?.-.-.-.-.-.-.-.-.-.-.-.-.-
Option 1: Take the heads off, decoke, and at the same time check valve seats and lap them in again if needed etc..-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-.-
Option 2: Add some Redex (or similar product that claims to clean the engine and remove carbon deposits) and "run like mad" one tankful to burn it off? .-.-.-.-.-.-.-.-.-.-.-.-.-
Option 3: Like 2, but only the "run like mad" part of it?.-.-.-.-.-.-.-.-.-.-.-.-.-
Option 4: Do nothing?.-.-.-.-.-.-.-.-.-.-.-.-.-
Of course, the like the engineer I am, option 1 is the only really good solution, but it taks some effort etc. etc, and may not be needed..-.-.-.-.-.-.-.-.-.-.-.-.-
Maybe option 2 would be OK? I am thankful for any inputs on this!.-.-.-.-.-.-.-.-.-.-.-.-.-
Regards, Anders F. R..-.-.-.-.-.-.-.-.-.-.-.-.-
PS. The bike in question this time is actually a 1956 BMW R50, but as the question might apply to any old, carburetted engine I take my chances here!
