- Tue Jun 05, 2012 10:42 am
#13225
Stu, Just before you replace the solenoid, check the connector on the cable from the clutch switch (three wires green/black/brown I think) You should be able to get to it without removing the headlamp by turning the forks to the right. It's a common cause but not always thought of. Good luck.
REgards, Mick.
REgards, Mick.
