- Wed May 30, 2012 6:11 pm
#544
2007 500 Classic. Hitchcocks 50s pipe. Tea caddy air filter. Mikarb jetted to suit. Boyer Mk 4 ignition.
I’m so utterly fed up with my bike that I’ve thought about cutting my losses and selling it as a non-runner. The bike has been lavished with attention. It’s immaculate having only covered 3500 km, but it’s so difficult to start that I’ve had enough. It’s an utter liability. I can’t use it for fear of being stranded - and yet when it starts, it runs fine. It ticks over slowly and evenly. No pinking.
It’s not that I haven’t got the knack – I’ve owned it from new. Sometimes it starts first kick. Most of the time though, it backfires, usually blowing the carburettor off and running backwards until it chokes itself. I know this will destroy the worm gear if left unchecked.
Tappets are fine. Carb has been off, cleaned and checked. Carb rubber has no leaks and the jubilee clips securing it are fine.
The Boyer Mk IV ignition (from our hosts) was fitted 18 months ago, and was fine. This year, the starting problem has emerged and has gradually got worse. I’ve re-checked the timing as per the instructions – anti-clockwise on the slots at TDC, then moved to mid position (I know that I can find TDC quite precisely). I’ve tried retarding it further - moving it fully clockwise on the slots. This must make static timing about TDC. All wiring is secure. Although I haven’t used a strobe, I do not think my method would put the timing far out. Still it backfires. Most of the time.
I know that battery condition is critical. Mine is about 18 months old. A volt meter tells me that it has a 12.6 volt charge that only drops to 12.4 volts over a period of days. My Optimate assures me with two green lights that things are fine. I’ve connected a ruddy great car battery in parallel, and still it back fires.
There is a degree of end float in the tapered shaft which now secures the rotor, “slop†if you prefer. This amounts to about 5 mm. The magnets and back plate are secure on their taper, but because of this “slop†they had been fouling the blobs of solder on the reverse side of the stator plate. I had thought that the magnets fouling the solder blobs were inducing a mis-timed spark. I've dressed this excess solder with a file, and fitted a cardboard gasket behind the stator to further increase clearance, and so the magnets no longer foul anything. The connections created by the solder have not been compromised by my judicious filing. Now I’ve painted the solder on the reverse of the stator plate thinking that this might insulate them and prevent a spark somehow being induced.
So that’s it. I’m at a loss.
My options as I see them are:
1. Sell it as it stands and buy a (Hinckley) Bonneville.
2. Re-fit the points and condenser. If I can work out the wiring.
3. Fit a new battery despite the positive indicators outlined above.
4. Put it in the shed and let my executors dispose of it in maybe 20 years or so.
5. Torch it.
Any thoughts anyone?
5. Torch it.
