- Sun May 20, 2012 8:01 pm
#496
I got stuck by the roadside today when the electrics of my Sixty5 went dead! The fuze was ok, then I checked the earth connection behind the battery box (a wire had broken there once before) and that was ok, and the rest of the visible wiring also looked intact. So I then ran a by-pass lead direct from the positive battery terminal to the positive terminal on the ignition coil - and lo and behold - it started first kick and got me home! I remembered reading about this tip once before, so when I first had the bike and was assembling "handy things" to put in the toolbox, I included a short length of electrical lead that had small crocodile clips at each end, just in case I ever needed to do it. So it's well worth having a bit of cable on board! With this by-pass in place, all the lights, the indicators, horn, etc, worked normally again, but the AMMETER was not registering. (It was converted to kickstart-only two years ago).
Now I have to fix it properly, so I would welcome any suggestions from the brotherhood as to a possible cause of the problem (I'm not very electrically minded). I'm hoping to find a loose lead or suchlike in the casquette - maybe at the ignition switch or the ammeter? From what I have described, is there something else that could be a prime suspect? (I won't be able to look at the bike further until next weekend). Thanks!
