- Sat May 19, 2012 8:22 pm
#12683
The Electra X that I tuned had no mods to the standard ports. I raised the compression to 9.2:1, fitted double valve springs and 'S' cams and the upgraded [not green] CDI box, I also tried 32,34 and 36 mm carbs on the dyno. The 36 gave the most power throughout the rev range, even low revs, the bike topping out at just over 100 mph when tested [erm I meant 60 mph, officer], the power reached 33.4 bhp at the rear wheel at 6,000 rpm.
