- Wed May 02, 2012 8:54 am
#12167
Been there, done that. My 1953 Model G had just the same symptoms, and the cause was the well known "old-magneto-that-doesn't-work-when-hot-syndrome" ....................................
As the others say, the magneto is likely to be the cause of this. What happens is that the insulation on the windings crakcs or something when it gets old. When it heats up, it short circuits and malfunctions. It may still run, but the spark is weak. As the voltage, and thus the spark strength, from a magneto increases with the rpm, the spark is too weak (or completely gone) when you try to kick it over when hot. When it cools down, it recovers.................................
Try the test that Les H describes. My best guess is that you will get a much weaker spark from the hot magneto, if any at all.....................................
If so, take the magneto to someone that can refurbish it. I did, and it has been just fine since then. It really takes a specialist to do it properly. .................................
Regards, Anders F. R.
