- Mon Apr 30, 2012 8:45 am
#384
Recently, after removing the primary chain tension adjuster and replacing it with our hosts rubber based one, the bike has developed a knocking sound. Rather ironic, as the rubber based one should cut down on any noise. I have since opened up the chaincase again, removed and put back the rotor and readjusted the chain which is neither too tight or too loose. In second gear at 20mph the knock is about once every second, and it only knocks when under load. The sound disappears when going down hills, or when the bike is stationary. There is no movement in the rotor or drive shaft, and I haven't discovered any metal filings in the oil, even after riding the bike several hundred miles with the knock. I'm wondering if this is a main bearing issue or not. The bike is an Electra X with 20.000 miles under the belt. I would be very grateful for any advice!
