- Mon Sep 24, 2012 2:06 pm
#1206
Was over in England last week and clocked up around 2,000 km almost without a hitch. The only hitches came as I was making my way back to a ferry and getting rained on in England (who'd have thought). I've had this problem for a while and failed to locate the problem but last week, in the rain, I think I found the reason for the problem if not the direct cause.
Basically the bike suddenly starts banging, spluttering and dies after some time in the rain, then it might eventually, restart, after a lot of kicking, but when you put it into gear and pull off it dies again. So been around a few things and decided that it must be water getting into the petrol. So last week on the side of the road, in the rain I dropped the fuel out of the carb float bowl. A few kicks and it was away. About an hour later in the rain we'd the same problem so dropped it again at the side of the road and off again.
So now I have the issue I have to sort out the source of the problem. Do all bikes have this problem or just my Bullet 500 with a KNR wire gauze air filter fitted? The air filter was on it when I bought it second hand. It's hard to see how the water's getting in when you're travelling. Maybe I need a snorkel
Is the wire gauze not a good idea? Oh it's an Amal carb which I fitted, but used the air filter which was on the original carb.
