- Fri Apr 27, 2012 7:24 pm
#373
Hi every one I have been for some time stripping my engine down for a big end job. After going on here for advice I have found it is invaluable, I found advice on the crank pin bearings and lots more. today I striped down the head and rockers' I am glad I checked the oil ways because as suggested on this site they was chocker block with big end debris I a lucky the top end did not seize up on its last run. The oil pump was also clogged with fillings. so please folks those who are thinking of doing a big end job don't take any chances clean every nook and cranny in the engine and if you see any fillings in your oil don't leave it to long.
THANK YOU ALL FOR YOUR PAST HELP AND ADVICE
Terry
Terry
