- Sat Apr 21, 2012 7:36 pm
#345
Just picked up a 2002 Classic 500 4 speed. Goes up through the box fine but when trying to down shift I keep getting false neutrals (almost every time) I am confident I haven't been hitting the neutral finder. It's been quite a while since I had a classic bike (Bonneville about 20 years ago) and I don't expect it the box to be like a modern Japanese bike but in a 15 minute ride through town you'd have thought I might have managed to downshift at least once successfully.
I checked the chain tension and it appears to be ok. It only has 1500 miles on the clock so has clearly been left sitting for long periods during it's lifetime. Not sure if it's been serviced at all. Is this 'normal' or something I'm doing wrong? I have read about the ratchet system in the gearbox - could adjustment here help things? The guy I bought it off said he had just adjusted the clutch - could this have any bearing?
Any ideas much appreciated (or any mechanic recommendations in N. Ireland (closer to Belfast the better)
