- Sun Apr 15, 2012 6:50 pm
#11586
Morgy, by coincidence, I bought two of these (part no 144497) only last Friday (13th) for my '92 500 because I wanted to fit the needle roller clutch pad. I was replacing the earlier one-piece rod so cannot confirm the old length. However, the new rods were each 129.10 mm which is closest to your original 5 1/16 in and the 128mm quoted in the online parts book. Perhaps a 1/4 in ball between the rods would be the answer, particularly as it would lie much closer to the shaft axis than a 1/8 in ball. I fitted the parts this morning without a ball between the rods but with the usual ball between the rod on the primary drive side and the needle roller clutch pad. All appears to be ok (it frees, starts, selects all gears etc.) but I haven't given it a road test yet.
