- Sat Sep 08, 2012 9:56 am
#1122
This follows on from the carb problem last month which has not yet been resolved. I seem to have a weak spark which has developed over the last month or two and may be the problem with the rough running which I put down to the carb. I have installed new points and condenser and set the timing. The plug is new and the mixture is very rich/sooty, it wasn’t and I haven’t changed anything on the carb – still standard. The spark is white in colour but the engine starts readily enough and ticks over when up to temperature, however under load it misses and jumps about.......The battery is showing 12.5 v with no load and drawing .25A with the ignition on. With the points closed it is drawing just over 3A and the coil starts to warm up – engine not running. With the engine running it still draws 3A but the battery lead is warm to the touch as is the coil. The coil resistances all seem to be within working parameters. My view is I need a new coil, however before going to that expense HAVE I MISSED SOMETHING? Many thanks Phil(PJ)
