- Tue Sep 04, 2012 10:17 am
#1097
Hi Allan R and others
I saw some comments about youre engine configuration in a post in a previous thread about topspeed, and it has got me thinking.
My configuration is:
500 Bullet
Micarb
Forged piston
Electronic ignition
Until a few days ago I ran a Bellmouth, with a freeflowing silencer but the original downpipe.
With a richer slide, a richer needlejet, a 30 pilot and a 130 main jet and the needle in the bottom groove (richest setting), it went really well (and fast - I have been very close to the ton (actual speed)).
However I got tired of it drinking water when it rained, so I changed to a teacaddy but installed a proper freeflowing pipe also.
It seems now, that I can only run a 120 main, and have had to drop the needle one notch.
In your post as mentioned above, you say, that you run a 130 main, with pretty much the same setup as mine (only with sligtly lower compression). How can that be?
Is my teacaddy more restrictive than yours or are you running rich but not fouling the plug because the denso plug can handle it?
Sorry for the long post and the bad english
Danish Dan
500 Bullet
Micarb
Forged piston
Electronic ignition
Danish Dan
