#81268
What Paul says. If you want you can use ATF Type F in the primary and forks, I do on my Mk1 and think the primary in particular benefits but others see no improvement. I also use a Hypoid gear oil in the gearbox, the Mk1 has a bushed mainshaft sleeve which can be troublesome, and for that reason I'd use something more modern. An alternative would be multigrade with a dash of Molyslip or similar friction reducer. Whatever you do, do not use monograde in the engine! There is a group for Interceptors, https://groups.yahoo.com/neo/groups/RE_Interceptor/info You will have to apply for membership as it is a closed group and this usually takes a few days. Got any pictures?
By Aethelric
#81274
There is an interesting article on oils here It's all about Norton Commandos but the technology is similar to the Interceptor, or a Bullet even.
By another Allan
#81275
I was going to mention Jim Comstock's test results, but you beat me to it!
Generally, any flat-tappet (i.e. not roller tappet) engines need higher levels of ZDDP than most modern oils contain.
By Aethelric
#81276
Most of the oils he mentions are not available in the UK. Castrol Classic comes up well though so that's what I have kust got for next oil change.
