- Sun Jul 01, 2018 9:09 pm
#8613
Hi, I've just received a stem nut clock from our hosts. It looks perfect and fits the stem nut very nicely. It's set to the correct time at GMT, but we're now on GMT+1 so I want to change the time. The instructions say "the time setting crown is located behind the bezel at the position of 3'clock" but I can't see anyway of getting 'behind the bezel'. Has anyone managed to get to the clock crown to set the time? If so, what's the trick? On a similar note, the instructions for changing the battery say 'insert a screw driver into the case notch at the side of the back cover' to access the battery, but I can't see any such notch and can't take the back cover off. Still, that's a problem for another day.
