- Thu Jun 14, 2012 9:09 am
#13582
Yeah Martin, I'm afraid that it may not be as simple as a warped primary cover - although of course you need to check it.
Mine looked like it was leaking (from new) from the bottom of the primary cover, which we changed to no avail.
After many investigations, which went on after the warranty expired, it was found that a sealed (capped) bearing from the gearbox/clutch assembly was leaking and dripping round down to the lowest point of the primary cover. Once stripped down and fixed it has been OK.
Another leak was traced to the oil pump cover gasket which again was allowing oil film down to the bottom of the crankcases - making it look like the leak was from there. Again, once replaced it has been fine.
I suugest a good clean down and discussion with the dealer who supplied the bike would progress this for you?
All the best.
