- Sun May 17, 2015 1:25 pm
#5081
Right A Little Story: Three Years ago I left My Std 350 98 (Home Mkt) Model in the garden (Using My AVL daily instead) ,Thinking It would Not be long I Squirted some WD 40 in the Carb & Put a Table spoon full of 2Stk oil in the Tank..Covered it in An old Bin Bag and....Zoom forward to Now..So this Morning I Drained the Old Fuel Cleaned the Spark Plug and re charged the Battery and She Started and Ran on her 2nd Kick & tick's over Nice.............Battery is a 5 tear Old RS Sealed one and Still Holds Charge..Old Petrol Look;s Fine with No Viz Water,Emulsion Ethinol etc...Tank Seems Fine Bit of Debris/Rust No Gunk or Hole's.Clutch Not Stuck or Sticking At all?.....Front Brake is Sticking And One Indi Bulb gone..Other wise All Seems OK..(But I will Oil & Filter Change afore Use) Last Note She is Still Running on the Original (Touch Wood) Points she left the factory On and Now has 35000 Miles on the Clock... "A Simple design Still working"....Cheers All Craig
