- Fri Aug 15, 2014 1:56 pm
#4050
Hello all,
The inlet manifold rubber hose on my sixty5 is starting to show some nice cracks, and it's started affecting the mix a bit (at first at least, until the engine warms up and the rubber expands and seals it's cracks). I've got two questions, if anyone cares to enlighten me a bit.
1.Until I get the replacement part, are there any tested hacks or temporary solutions that can be applied? I was thinking I'd tape all around the rubber hose with electric tape, but I'm not quite sure if it's strong enough to withstand the temperatures. Any ideas for a temporary way to seal the cracks would be most welcome.
2. I have a bit of a cramped situation at the throttle cable end of the carb, it sits really close to the tank. Nothing is getting bent or anything, but still I think it would be better to have some room there, if only to make work in that area easier. Seeing as I will be replacing the rubber hose anyway, I thought I could kill two birds with one stone and maybe find a shorter hose, to move the carb a bit closer to the cylinder. Does anyone see any potential problems with that? Also, are there different diameters between different models, or is it pretty much the same?
Kostas
Kostas
