- Thu Apr 09, 2020 10:02 am
#89117
Thread lock this is another one that I think we should talk about
Thread lock's come in different types I don't know all of them but will talk about the one's I use for different jobs, in 50 odd years of turning spanners and bodging old machinery I may have got set in my ways and not be up to date
The one's I use are
Blue universal
Red high strength heat resistant
Green course thread, high strength, heat resistant, and creeping
Firstly I know people that use only blue and have no problems
Secondly I'm not going to tell you what to use where that's for you to decide I will just give a couple of examples of what I would use and where.
Blue I use for things like fork pinch bolts, fork damper bolts, luggage mounts, mudguards etc
Red I tend to use for engine internals, exhaust studs, etc
Green gets used for thing's like that indicator that keeps vibrating lose tighten it up add a drop of green to the outside of the nut it will creep in and solve the problem, also for engine mounts use it the same way just a drop on the thread where it comes through the nut.
I will also use red or green on thread inserts and carb studs red for finer threads green for courser threads, after fitting the insert grease up the fitting it's going to be used with screw it in to set the insert remove the fitting and leave overnight.
(sorry folks I really struggled with that!)
Any questions just ask I will try to help
For engine casing screws I don't like to use thread lock, due to the fact that the threads are often worn to begin with I just use a smear of hylomar
Oil drain plugs again hylomar
Quill bolt on bullets again hylomar
For anything that doesn't go tight (carb flange nuts etc) hylomar
I think I have covered most things any questions please ask Dai
Dyslexic sorry folks can't help that
Owner of asbo 30
Please remember most carburetor problems are electrical!
