By Tomshayes
#72609
picture hosting
Looks like I've got to cut a channel to allow clearance for the 5 speeders rearset to operate.. I like the look of the original Clubman S so I'm keeping the tool boxes... Plus they come in handy....
#72612
Hi Tom-------- cutting into the toolbox is going to be a bit drastic I would have thought ?-------From looking at your photos it seems like you could re-drill the clevis pin hole a wee bit lower, maybe an inch ??......That should give the needed clearance for the linkage rodding...........Also, as you are now going to fit the roller big-end you might want to consider our hosts uprated oil pump conversion...... This is to increase the flow-rate NOT the pressure.....Good luck and keep "The Faith" !!
By Tomshayes
#72616
Yes that thought eventually crossed my mind lol.. And yes I was also fitting the higher flow pumps..
REgards Tom
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 13
