- Thu May 05, 2016 7:23 am
#57889
Hi Terje,
Had exactly the same problem with the team's 500, it would only run on choke, Ok at idle but pops and bangs higher up. Larger jetting 135# cured it. India tends to set there bikes on the weak side for economy, and bear in mind you are running a modified engine without a filter. Q what exhaust are you running? as that will also contribute to any variation to the normal settings. Vince
ps it maybe a quirk of that individual carb as two different carbs may give differing results.
