- Sat Aug 13, 2016 10:47 am
#61142
With only 1000 miles on the clock the engine is over the hump but still running in, so fur or paste on the magnets is normal and even to be expected throughout its life, what we don't want to see is big lumps.
Yes the handbook calls for a semi-synth which is about as good as they get in India. The thing is to meet the same spec 15W50 API SL Grade JASO MA. The latter part is the spec for wet-plate clutch - it it doesn't meet JASO there is a chance the friction plates can unglue because they're attached with a water-based cement (because they run in 'solvent'). Having had 350,000 miles out of an engine on syth, I'm convinced it is better than semi, but that's me.
The indian domestic models are not built to the same spec as the export models. There are a number of differences. Different tyres for a start. The ECU on the export is marked "Export" so expect different mapping, and is the 2010 domestic supposed to have that O2 sensor or not?
The decompressor 'clack' should disappear at 700rpm and/or within 10 seconds, it is a bit of a variable function but should improve as the motor beds in a bit more. Should start up, "click, click, click, click, CLACK!", and the motor picks up.
The flat spot just above tick-over is the EFI.
It may be improved by raising the idle a /little/ (brass screw hidden on throttle body, about 1050rpm) and eliminated with the Power Commander V (PCV) (with Hitchcocks' mapping and some fiddling about on the laptop).
Using the laptop is equivalent to re-jetting and adjusting a carburettor, but without stripping anything out. It's a pity the stock ECU doesn't have any adjustment or allow for remapping.
But the domestic ECU is the domestic ECU and I've got no idea what you've got in there.
