- Mon Aug 31, 2015 7:17 am
#50680
Thack,
I thought the lever fooled the efi into injecting more fuel , like for a cold start?
I don't Have Thunderbolt to check on anymore, but apparently, the RE ECU can be reset if it has made a hash of things.
ECU RESET:
Check for all the sensor connections plugged in properly and then reset the system by the following procedure.
Switch on both the ignition key and kill switch wait, for 10 sec then completely open the throttle for 10 sec, then release the throttle, after 5 sec mil will blink continuously twice, reset completes.
Then switch off the ignition and switch the ignition key on again. wait for 3 sec then start the engine.
(note during reset procedure the engine should not be running, only the ign. Key and kill switch is to be turned on.)
Will it work? I don't know. I would say use at your own risk, but if somebody does try it out or knows if this is correct, do let us know here!
Thack,
ECU RESET:
REOC 15084
Tabellarius de verbis. Ostensor gaudium
