- Sun Dec 29, 2013 11:33 am
#31276
Hey Oudaios - I think that it will be more a case of you not finding the drain plug rather than it not having one! In a nutshell there are THREE 'drain plugs' under there each there for a different reason. My guess is that all you have done previously in drain the crankcase rather than the oil tank. As has been suggested by MIDGE, look on here under 'Technical Notes' at the side of this page and you will see a great diagram showing you exactly what I'm talking about. You'll need to remove the rear-most drain plug to drain the oil tank and the front-most one to drain the crankcase. When you refill the bike remember to leave some oil aside while you run the engine and allow the oil to circulate - then top up again. Hope this helps! Riggers.
